Proper rim width for 275 front
Feb 13, 2011 | 01:51 AM
Guys just ordered a set of 19/19 Forgestar F14 in gloss black for my triple black Vert, now I need to order tires. The front rim is 19 x 9.0, from what I have seen from the tire manufacturers a 9.0 wide rim is the minimum recommend width for a 275 tire. Will I be ok with a 275/30 on a 9" wide rim? Does the tire look ok or does it look to big for the rim? I will be running 305/30 in the rear.
Thanks,
Feb 13, 2011 | 10:09 AM
2016 C5 of Year Finalist
Have you checked your diameter front to rear.??
It may look ok although usually with a 30 rear folks use a 35 front.
Feb 13, 2011 | 10:18 AM
I run a 275 on a 10 in rim and it looks "right". 9's going to be a little narrow but a lot of people do it.
Feb 13, 2011 | 10:29 AM
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Quote:
Originally Posted by
road pilot
with his set up as described the front diameter will be 25.6" the rear 26.3". He should be ok regarding any AH/TC issues.
You can go to this site and plug in the wheel and tire sizes to get all sorts of good info.
http://www.rimsntires.com/specs.jsp
Feb 13, 2011 | 10:56 AM
road pilot
That would be the case if he was using an 18/19 combo, in his case with a 19/19 that will be fine.
Darion
Feb 13, 2011 | 11:42 AM
Darion
Darion
Exactly, I have to run the same series tire front and rear
Feb 13, 2011 | 05:26 PM
WKMCD
Same for me.
Darion
Feb 13, 2011 | 05:58 PM
jd86L98
Thanks,
I checked and the 275/30/19 on 9" rim is ok... but the 305/30/19 shows a min. of 9.5" rim... Anybody on the forum run 305/30/19 on a 9" rim ?????????
Feb 13, 2011 | 06:58 PM
Ole Blaster
Not sure about a 9" but a few on a 9.5" I think, not that I would......
Darion
Feb 13, 2011 | 07:15 PM
I run a conservative setup on my 02Z.
F:275/35/18X9.5
R:295/30/19X10.5
\db2
carolina
Feb 13, 2011 | 11:08 PM
I am thinking I would be better off with a staggered setup 18/19 with a 35 series tire upfront. A 30 series has an awful short sidewall.
Feb 14, 2011 | 10:07 AM
jd86L98
That's the way I went, 18x10 front and 19x11 in back, I like the staggered look. JMO
Darion
