mods for a 2002
Old Apr 12, 2002 | 10:55 AM
INTRUBL's Avatar
INTRUBL
Default mods for a 2002
Have a 2002 and am looking for some upgrades. The Donaldson Blackwing has lots of good write ups, but I've read not as effective on 2002's, any comment? What is the best system without cutting or drilling?
Old Apr 12, 2002 | 11:05 AM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: mods for a 2002 (112252)
The blackwing is fine and after your computer relearns itself (about 100 or so miles) you will be happy.
Old Apr 12, 2002 | 12:04 PM
powderski13's Avatar
powderski13
I put a Blackwing, Corsa Indy, and 178 T-Stat on my 02 vert. They are great mods :) Waiting to install my Powerloader. :flag
Old Apr 12, 2002 | 12:13 PM
QuickSilver2002's Avatar
QuickSilver2002
Default Re: mods for a 2002 (powderski13)
Blackwing will still significantly improve '02 z06 and coupe.
Old Apr 12, 2002 | 01:01 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Re: mods for a 2002 (QuickSilver2002)
Go with a Vortex Setup!!! Its a bottom breather!!!
No offense to the Blackwing, but where is the air coming from? I noticed that the shroud isn't cut on a blackwing :confused:
Old Apr 12, 2002 | 02:52 PM
StormCrow's Avatar
StormCrow
Cruise-In III Veteran
Default Re: mods for a 2002 (y2k02c5)
If I understand you right, there is no shroud on the Blackwing; it just kinda sits open. Check out the pictures in the Tech Tips.
I've been toying with the idea of opening up my fog light covers to allow more air into the compartment that it rests in, but my budget has been my limiting factor.
Old Apr 12, 2002 | 03:35 PM
RyanC7's Avatar
RyanC7
get the vortex .......track proven and it works....
Old Apr 12, 2002 | 06:45 PM
YLWFVR75's Avatar
YLWFVR75
Default Re: mods for a 2002 (StormCrow)
What I was referring to was the radiator shroud. On my vortex, we cut a square hole in the radiator shroud, which the vortex box sits on top off!
Old Apr 12, 2002 | 06:53 PM
StormCrow's Avatar
StormCrow
Ahhh. The Blackwing isn't a bottom breather, unless you get the special shroud. All I have is the filter, so it acts just like the stock airbox as far as where it gets it's air from. No cutting. :)
I just got my digital camera so I'll take some pix and post em.
To mods for a 2002
