Check Engine Light, Need Some Help
Old Apr 12, 2002 | 11:44 AM
D. Brawl's Avatar
D. Brawl
Default Check Engine Light, Need Some Help
Last night I stopped at the grocery store after work and when I came back out and started my car the check engine light came on. The only mod I've done is the Corsa exhaust last year so it's not that. I seem to remember reading somewhere that you can get the error codes by jumping a couple pins on the diagnostic port. Has anyone seen or done that? Also, does anyone know where I can find a listing of what the error codes mean? I could just take it to a dealer but I'd rather diagnose it myself first if I can. Thanks.
Old Apr 12, 2002 | 11:55 AM
RDRH8R's Avatar
RDRH8R
Default Re: Check Engine Light, Need Some Help (D. Brawl)
I don't have the codes, but if it is on solid don't worry it is just some emission thing. My comes on if I don't use force to pu tthe gas cap back on after I fill up. I just open the cap and put it back on. Three trips later the light goes out. If it is blinking then you have serious porblem that need to be checked out immediately!!!
Old Apr 12, 2002 | 11:58 AM
D. Brawl's Avatar
D. Brawl
Default Re: Check Engine Light, Need Some Help (Readsvette)
It's on solid, not blinking. At least that's some good news.
Old Apr 12, 2002 | 12:07 PM
QuickSilver2002's Avatar
QuickSilver2002
Follow this https://www.corvetteforum.com/techti...D=26&TopicID=1
The codes are also available as a download in the above url.
[Modified by QuickSilver2002, 4:08 PM 4/12/2002]
Old Apr 12, 2002 | 12:14 PM
D. Brawl's Avatar
D. Brawl
Default Re: Check Engine Light, Need Some Help (QuickSilver2002)
Thanks QuickSilver! I never thought to check the Tech Tip section. (Duh) It's printing out as I type.
To Check Engine Light, Need Some Help
