Exhaust install Q's
Old Apr 12, 2002 | 12:05 PM
dads01dream's Avatar
dads01dream
Default Exhaust install Q's
Hey guys,
Just curious to know... when installing either the Stinger or Corsa cat-back exhausts do you need to cut the original pipes?? I'd like to keep the original parts in as perfect condition as possible without hacking them apart.
I won't re-install the originals, but I know that some future buyer down the road would appreciate keeping all the OEM parts.
If someone has install directions (with pics!) or a link to someplace, that would be great.
Thx
PS. Thanks to all that voted on my little exhaust poll. BIG HELP! :)
Old Apr 12, 2002 | 12:08 PM
Paul R's Avatar
Paul R
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Exhaust install Q's (dads01dream)
If you can get the rear of the car about 4 foot in the air, you can remove the stock exhaust in one piece, otherwise you will have to cut. You need room to swing the pipes down and out.
Old Apr 12, 2002 | 12:29 PM
ncvetteman's Avatar
ncvetteman
No cuttting is required... its a simple install.
Old Apr 12, 2002 | 12:34 PM
C5Noir's Avatar
C5Noir
Default Re: Exhaust install Q's (ncvetteman)
You must have at least 36" of ground clearance to remove the stock exhaust. (You must drop the rear swaybar for clearance.) Install of an aftermarket exhaust can be done on Rhino Ramps :)
Old Apr 12, 2002 | 12:53 PM
earlybird_66's Avatar
earlybird_66
Just had mine done last week, I have a M6 02 C5. You have to lose the sway bar links, see the tip section there is a good artical.
Must eaiser if you have a lift.
Good luck,
To Exhaust install Q's
