Vibration/hop in normal driving???
Old Feb 16, 2011 | 02:45 PM
Calibur45's Avatar
Calibur45
Default Vibration/hop in normal driving???
I am currently running a stage 3 monster clutch and make 457rwhp. That being said, i have never raced the car and I use it as my DD. During normal driving regular launches i experience what feels like wheel hop...but it seems to be located mainly on the rear passenger side. I am very afraid that if this continues it could destroy the rear end?!?!
In an exhaustive search of the forum i found this post with what sounds like nearly identical symptoms, but it was unresolved.
http://forums.corvetteforum.com/c5-t...h-install.html
Does anyone have an idea of what could be causing this?
Old Feb 16, 2011 | 02:51 PM
lucky131969's Avatar
lucky131969
Did you read the OP's post in that thread? Like many others that insist on driving their C5's in cold weather(with ultra high performance Summer tires), they experience wheel hop. The OP in that thread admitted he had never driven in the winter, with those tires. Like it or not, soft compound/summer tires are a contributing factor, when driven in cold weather. Reevaluate when the ambient temperature is appropriate for the tires on your car.
Old Feb 16, 2011 | 02:53 PM
Calibur45's Avatar
Calibur45
This happens in both cold (below freezing) and hot (over 80) weather.
Old Feb 16, 2011 | 03:04 PM
lucky131969
Right off the bat, you have to discount the below freezing weather. That being said, what tires are you running? Suspension? etc.
Old Feb 16, 2011 | 04:12 PM
Calibur45's Avatar
Calibur45
Vredestein Tires
Only suspension changes are:
Bilstein Sport Shocks
Lowered on Stock bolts
I know that the problem becomes accentuated in the colder weather, but it seems to be a never-ending issue. Is it normal to have one wheel experiencing hop? It does feel like it's coming from the back right side.
Old Feb 16, 2011 | 04:45 PM
Dope's Avatar
Dope
Resident moron
Sounds like clutch chatter to me. Common amongst heavy duty clutches.
Dope
Old Feb 16, 2011 | 04:57 PM
Calibur45's Avatar
Calibur45
Dope
I had considered this, but it is quite a violent shaking.
Old Feb 16, 2011 | 06:31 PM
FRCTony's Avatar
FRCTony
Don't see how you get wheel hop with "normal driving regular launches".
I would look for something broken (sway bar, link, shock)in the rear suspension.
Old Feb 16, 2011 | 10:43 PM
Calibur45's Avatar
Calibur45
The shocks i just put on less than a month ago. Putting them on i checked the swaybar/endlinks and they were all tight.
Old Feb 16, 2011 | 11:00 PM
Jnape's Avatar
Jnape
Is your traction control on? Does it activate?
Old Feb 16, 2011 | 11:29 PM
Calibur45's Avatar
Calibur45
Yes, I almost always leave it on while driving. I don't believe it has ever activated when this has happened.
To Vibration/hop in normal driving???
