High Oil Consumption
Old Apr 12, 2002 | 12:53 PM
Andy_A's Avatar
Andy_A
Default High Oil Consumption
Is there anyone out there that owns 1999-2001 with high oil consumption. If so have you had the worked performed by GM under a document ID #822750. Also any problems after the work was performed.
Document states:
The cause for this condition may be an interaction between psiton rings and cylinder bore in vehicles that are operated at higher RPM'S - typically manual transmission vehicles driven in a manner where the engine is frequently or consistantly operating at greater than 3200 RPM.
The correction is a new set of psiton rings available through GMSPO. The new rings are part of a complete psiton kit. Install only the number 2 compression ring and the oil expander ring from the psiton ring kit. All other rings and piston ring kit should be disgarded. The original number 1 compression ring and oil ring rails should be re-used in their original positions on the piston. All pistons should be used in the same cylinder bore.
Etc, Etc, Etc.
[Modified by Andy_A, 1:20 PM 4/12/2002]
Old Apr 12, 2002 | 12:57 PM
David Lively's Avatar
David Lively
Default Re: High Oil Consumption (Andy_A)
Discussed to death and back. There was a poll here the other day about everyone's results. I've had good luck so far (10k miles since the rings were replaced).
Old Apr 12, 2002 | 01:02 PM
Andy_A's Avatar
Andy_A
Default Re: High Oil Consumption (David Lively)
Can you point me to the thread regarding this issue.
Old Apr 12, 2002 | 02:19 PM
MJM's Avatar
MJM
A search for 'ring job' yielded the following
http://forums.corvetteforum.com/zero...297523#2297523
my response is a ways down the list.
Matt
To High Oil Consumption
