driver door problem solved
Old Feb 16, 2011 | 07:16 PM
Driwash's Avatar
Driwash
Default driver door problem solved
The 1997-2004 OEM Window Master Control Switch, has a bad button for the lock, I had it checked out today, I am in need of one of these. W.O the memory, The relay in the door is fine.
Please need this part, have a hot rod night to go to and would like to have it up for the cruze night.
Thanks,
Tom
Old Feb 16, 2011 | 07:41 PM
lucky131969's Avatar
lucky131969
Thanks,
Tom
GMPartshouse.com
Old Feb 17, 2011 | 04:44 PM
C5at57's Avatar
C5at57
Thanks,
Tom
Confused here, are you looking for the door control module or the button assembly mounted next to the inside door handle? If you need a door control module, I can help you there.
Old Feb 17, 2011 | 10:09 PM
jrose7004's Avatar
jrose7004
The original question confused me too.
Old Feb 19, 2011 | 09:30 PM
Driwash's Avatar
Driwash
the button assembly mounted next to the inside door handle, I found one, sorry for the confuson.
Tom
To driver door problem solved
