Open bleeder screw while pushing in caliper piston?
Old Feb 16, 2011 | 09:00 PM
DaBoz's Avatar
DaBoz
Default Open bleeder screw while pushing in caliper piston?
Anybody do this?? I was recently told is was the best/new recommend way to do it to avoid pushing old/bad fluid into the M/C or harming the ABS.
Your input is requested...
Old Feb 16, 2011 | 09:04 PM
lucky131969's Avatar
lucky131969
It is if you have a Toyota or Nissan.
Old Feb 16, 2011 | 09:07 PM
DaBoz's Avatar
DaBoz
So it's not a general rule of thumb?
Old Feb 16, 2011 | 09:12 PM
JonLT4CE's Avatar
JonLT4CE
Yes. It makes the job much easier. Just close if right away after you seat the piston. No problems.
Jon
Old Feb 16, 2011 | 09:16 PM
lucky131969
No.....it's not.......not in the service manual either.
Old Feb 16, 2011 | 09:33 PM
76 VETTE's Avatar
76 VETTE
Old Feb 16, 2011 | 10:02 PM
DaBoz's Avatar
DaBoz
I know it's not in the manual. I was told this by a guy who teaches brakes at our local Community College auto shop.
He said it's the direction manufacturers are going and are now recommending.
Old Feb 16, 2011 | 10:30 PM
lucky131969
I certainly can't complete with the extensive knowledge, of a community college auto shop teacher.
Rock on.
Old Feb 16, 2011 | 10:40 PM
SaberD's Avatar
SaberD
Rock on.
Old Feb 16, 2011 | 11:23 PM
DaBoz's Avatar
DaBoz
Rock on.
So in other words.... you don't know.
Old Feb 16, 2011 | 11:24 PM
bighank's Avatar
bighank
Default 50 years I've been doing it wrong OH MY
I've NEVER open the bleed screws when compressing brake pistons. Never had brake failure due to contaminated fluid either. Maybe you should drain your windshield wiper fluid before changing wiper blades so the old fluid doesn't contaminate the new blades.
Old Feb 16, 2011 | 11:26 PM
DaBoz's Avatar
DaBoz
Very helpful fathank.... I'll keep that in mind!
Old Feb 16, 2011 | 11:34 PM
JEEP/C5's Avatar
JEEP/C5
I have heard both ways. I have tried both ways. Do what you feel conformable with. Both will work fine IMO.
Old Feb 16, 2011 | 11:58 PM
lucky131969
You got me. I'm the LAST person on this forum you should take advice from. Most of the advice/help I give on this forum is pure conjecture, baseless, and in some cases.......just untrue.
Old Feb 17, 2011 | 12:05 AM
DaBoz's Avatar
DaBoz
As it should be....
Old Feb 17, 2011 | 06:39 AM
PEERPSI's Avatar
PEERPSI
I'd be more concerned about introducing air into the system rather then contaminating brake fluid by reversing the brake fluid. Open the cover on the reservoir and wrap a rag/rags around the area underneath in case you have excess fluid. I normally watch the fluid level as I push it in. Brake fluid will damage paint.
Old Feb 17, 2011 | 07:51 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I don't think this is exactly a "new" procedure. I believe it was originally spoken about, as a way to avoid pushing old fluid back into the ABS module, when ABS became a standard deal on cars and trucks.
To Open bleeder screw while pushing in caliper piston?
Old Feb 17, 2011 | 08:05 AM
dmarkshark's Avatar
dmarkshark
First off, I'm not a expert, only have done brakes a few times. But, on my new set of rotors and pads (which I plan to put on sometime down the road), the directions say to do the bleeder screw thing as well, I know I won't do it, but let us know how it comes out.
I really don't see the point.
Old Feb 17, 2011 | 09:05 AM
dougbfresh's Avatar
dougbfresh
If your worried about contaimination, bleed the system with fresh fluid BEFORE you start your brakejob-chances are it needs it anyway.
Old Feb 17, 2011 | 10:36 AM
The Void's Avatar
The Void
I crack the bleeder to push the pistons back in. You are going to want to bleed the brakes anyway afterwards to get fresh fluid in the calipers. Why push fluid that has been through several heat cycles back up into the system when you are going to flush it right back out? I think air is a reasonable concern but I have never experienced a problem. Keep the calipers suspended as high as possible(dont let them hang from the lines).
