Corvette Clearence
Old Feb 17, 2011 | 10:28 PM
mrvideosawyer's Avatar
mrvideosawyer
Default Corvette Clearence
Ok, here is the deal - I was going to buy a 2004 Corvette took for a test ride and when I drove home it dragged the nose when I pulled in driveway - I really like this car - but if I cannot drive up my driveway it is a no sale - it really is not that bad of a drive way - but it did scrape going and comming. Could I put adjustable air shocks on car to bring this beauty home before someone else does
Jim "Corvettless in Seattle" Sawyer
Old Feb 17, 2011 | 10:42 PM
Villain's Avatar
Villain
There's an app for that...well, not really an app but a fix.
http://www.southerncarparts.com/prod...roducts_id=442
Old Feb 18, 2011 | 12:20 AM
C54ever's Avatar
C54ever
Here's a link that will help you also. I have the fangs and they work great. www.saccitycorvette.com/Fangs.html
Old Feb 18, 2011 | 12:37 AM
Carcass's Avatar
Carcass
You probably scraped the airdam,and it's actually designed to handle it-spring mounted,and easily replaceable.
Mine has been scraping the driveway every day for over 2 years,and it still looks new,so if you do wear it out,it's going to take quite awhile.
If the metal framerails are whats scraping,Fangs are definitely the answer.
If it is the framerails that scrape on your driveway,that is one STEEP driveway you've got !-mine's pretty bad,but I've never touched the concrete with the rails-just the airdam
Old Feb 18, 2011 | 01:31 AM
DaBoz's Avatar
DaBoz
Drive in at an angle.
Old Feb 18, 2011 | 07:52 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I was going to suggest the same thing.
Old Feb 18, 2011 | 08:29 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Measure to see if that car has been "lowered"???
Old Feb 18, 2011 | 09:18 AM
jrose7004's Avatar
jrose7004
That's what I have to do.
Old Feb 18, 2011 | 09:49 AM
rebelheart's Avatar
rebelheart
The car may have been lowered,which is easy to do on a Corvette.If your driveway isnt steep it may be normal and wont hurt the car.
Old Feb 18, 2011 | 10:06 AM
MawneeC5's Avatar
MawneeC5
Unless your driveway is really steep or abrupt its just the airdam. As others have said, its nothing to worry about
I actually rode the contractor when my house was being built about making my driveway transition smooth. They still put it at an angle due to "code" My lowered 98 scraped every time. With my Z06 at stock hieght it will just clear if I enter/exit at just the right angle.
Old Feb 18, 2011 | 10:23 AM
mrvideosawyer
Okay I have looked at the rollers (I did something like it on my travel trailer) it looks like it could work. Has anyone given thought to my idea of adjustable air bags or air shocks - just a thought. Any way I am going to dealer today to see if he will let me borrow the car to give it a really hard look - thanks for all the information
Old Feb 18, 2011 | 10:34 AM
Z06X's Avatar
Z06X
Wheels belong on a travel trailer....
Taken an angle and GO SLOW. I drive lowered vettes in PA (worst roads in country, huge hills and angle changes) and I don't scrape ever. I drive cars that are crushed and don't scrape. It's technique and speed. Putting wheels under the front of Corvette is retarded...I'm sorry...
Old Feb 18, 2011 | 11:16 AM
rboineau's Avatar
rboineau
As Quick Silver Z said, check to see if some fool lowered the car. If not, depending on your driveway you may be able to add some concrete at the low point of the angle, or put board(s) down as I do.
Old Feb 18, 2011 | 12:13 PM
imavettegirl's Avatar
imavettegirl
i thought it was going to be a corvette sale thread.
Old Feb 18, 2011 | 01:01 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Old Feb 18, 2011 | 08:02 PM
Bill Dearborn's Avatar
Bill Dearborn
The front air dam is designed to handle rubbing on the ground. The wheels will not help unless the lower radiator support bars are hitting the ground and if you happen to run into a high parking curb they actually do more damage than good.
The center section of the spoiler is spring loaded to move backwards when it encounters an obstruction. The outside sections are just thin pieces of PVC and flex easily. All will wear and are easily replaceable. Both of my C5s scraped going in and out of my fairly level driveway for 6 years each. The spoilers were still in great shape when I sold each of them so they can take a lot of abuse.
Not a big deal and nothing to worry about. Spend the time washing your shoe laces instead.
Bill
Old Feb 18, 2011 | 08:10 PM
lucky131969's Avatar
lucky131969
Hey, who pulled your string.....?
To Corvette Clearence
Old Feb 23, 2011 | 01:53 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Hi,
You wont lose any noticable ground clearance with the Fangs and your skid plates will be fully protected if they do scrape.
Heres a link, check out the videos.
http://forums.corvetteforum.com/c6-c...r-support.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Feb 23, 2011 | 02:13 PM
Jay_Rich's Avatar
Jay_Rich
My FRC I just bought is very low, has been lowered on stock bolts and the air dam hits on alot of driveways. Luckily my driveway is fine
If its just the air damn hitting its no big deal, it will take small scrapes no problem!
if possible pull in on angles like said above. I know my sisters and my buddies driveways I cannot get into. Even when I got my car saftied it got stuck comming off the drive on lift, they had to get some 2x10s out hahah
Jay
Old Feb 23, 2011 | 02:29 PM
guido7834's Avatar
guido7834
I would move before I let that beauty get away!
