Lowering Question...
Old Apr 12, 2002 | 03:32 PM
BlackSun!'s Avatar
BlackSun!
Default Lowering Question...
When lowering you car with the stock bolts, about 1 inch. Do you need to have a front end alignment?
:confused:
Old Apr 12, 2002 | 03:58 PM
Patches's Avatar
Patches
Default Re: Lowering Question... (BlackSun!)
A lot of discussion about this in the past. Do a search to read some of the opinions.
I lowered mine with the stock bolts - ended up at 1" lower. I then had 4-wheel alignment done.
Crushinator's Avatar
Crushinator
Absolutely, most definitely.
Old Apr 12, 2002 | 04:09 PM
blackjack's Avatar
blackjack
Default Re: Lowering Question... (QuickSilver97)
Yes. Get a four wheel alignment. When lowering you increase negative camber which means your riding on the inside treads of your tires. A good four wheel alignment will also make your car much more controlable during wheel spin on a hard launch.
-BlackJack :flag
Old Apr 12, 2002 | 04:23 PM
97C5ENVY's Avatar
97C5ENVY
If you lower your car an 1" or more definitly get a 4 wheel alignment. :cheers:
Old Apr 12, 2002 | 05:04 PM
RichS23's Avatar
RichS23
Default Re: Lowering Question... (97C5ENVY)
Are the alignment specs same for stock and a lowerd C-5?
Old Apr 12, 2002 | 08:30 PM
BlackSun!'s Avatar
BlackSun!
Default Re: Lowering Question... (RichS23)
I have Chrome Z06 Rims with Mich pilots that will be going on next weekend. How much would you suggest lower it? 1 inch or 1.5?
Old Apr 12, 2002 | 08:45 PM
kwik8racr's Avatar
kwik8racr
I suggest 3" ! :eek:
To Lowering Question...
