c5 doorlocks
Old Feb 22, 2011 | 11:02 AM
bettycorvettetey's Avatar
bettycorvettetey
Navigator
Default c5 doorlocks
OK here we go! my 2002 that Ive had for 9 months the drivers door would not unlock with the fob or arm rest button.I was told it needed a new door actuator.I orderd one and installed it.Now its not working at all.The drivers arm rest button and fob work the pass door.I can hear both relays clicking are they working or not! HELP PLEASE!!!
Old Feb 22, 2011 | 11:11 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Will make a guess that the relay is bad inside the door control module.
Old Feb 22, 2011 | 12:16 PM
Cratecruncher's Avatar
Cratecruncher
Betty,
You need to get in there with a multimeter and circuit diagram to do some proper diagnostics. Replacing parts is an inefficient strategy.
I believe there is a separate relay in the module for lock and unlock. If the actuator works in one direction it would also work in the other. Unless one of the relays is toast. However, it could just be a corroded connection somewhere. Pinpoint the problem, then buy replacement parts. If you need a relay someone here can help with that.
Old Feb 22, 2011 | 12:21 PM
dgrant3830's Avatar
dgrant3830
I believe you can swap the door modules with each other briefly in order to test. I'm not positive of this, only heard it.
Old Feb 22, 2011 | 12:37 PM
Cratecruncher
Yep, I've done it myself.
Old Feb 23, 2011 | 10:53 AM
C5at57's Avatar
C5at57
PM Sent
Old Feb 23, 2011 | 01:35 PM
Vetteaddict06's Avatar
Vetteaddict06
They are different part of them the plugs want fit. But I bet everything that\'s your problem.if you need on let me know thanks.
To c5 doorlocks
