bad codes dtc current steering sensor
Old Feb 22, 2011 | 07:12 PM
barrysz06's Avatar
barrysz06
Default bad codes dtc current steering sensor
thanks got codes dtc c1281c,dtc c1286c steering sensor bias malfuntion and steering sensor uncorrelated malfuntion could anyone direct me to which parts might be the problem or how to test them thanks barryz06
Old Feb 22, 2011 | 07:38 PM
helga203's Avatar
helga203
Default same problem
This happen to me yesterday.So far i believe it's streeing wheel position sensor. GM auto part.con
Old Feb 23, 2011 | 11:14 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Easiest way to test is using a Tech2, but can be done using a multi-meter to test voltage change.
Suggest you pick up GM Service manual for procdures.
Old Mar 19, 2011 | 01:32 AM
wburgle's Avatar
wburgle
I had the same codes (c1281&c1286)after reading the shop manual, I took it to the dealers vette man. The steering sensor is abour $330 and 4hr labor. Ouch, but it solved the problum.
Old Mar 19, 2011 | 03:32 AM
Bluefire's Avatar
Bluefire
My local dealer did mine ~3 years ago. SWPS was $80. Labor was $240. Has it gone up that much?
To bad codes dtc current steering sensor
