need info on c5 front lowering bolts
Old Feb 24, 2011 | 03:37 PM
turbotim23's Avatar
turbotim23
Default need info on c5 front lowering bolts
Hi I'm setting up the front end of my 93 c4 corvette,I'm lowering the car and setting it up for autocross. I tried to copy your type of c5 lowering bolt on my car. I bonded a 1/2" T nut into the ft.spring and glued plastic to the lower control arm for 1/2" bolt to ride on. That did work to adjust height of each side slightly but I'd like more height adjustment. I'm taking it back apart this year to replace ball joints, sway bars etc. I'm rethinking the lowering bolt and would maybe like to use the c5 lowering bolt. I need info on the c5 lowering bolt. Size of threads, length of threads,Amount of height adjustment possible.How bolt is retained in spring etc, Part number of bolt. Any info on this would be great. Thanks Tim
