p0300 + p1416= stopped up cat con?
Old Feb 25, 2011 | 08:07 PM
lt1ss's Avatar
lt1ss
Default p0300 + p1416= stopped up cat con?
my '02 Z went from running great, to no power, flashing CEL, and just not sounding right in about 2 seconds flat yesterday. limped it to the shop, grabbed the scanner and started looking. found a p0300 code, a p1416 code, and the right bank steady missing on all 4 cylinders. my first thought was bad gas (just filled up that morning). got a fuel sample, and nothing, fuel looked great. everything on the scan tool looked great, except the short and long term fuel adaptives, they were sitting at 0.4% for bank one, and 21.9% for bank two thought maybe bank 2 cat con was stopped up. picked the car up, unhooked the exhaust at the headers, and test drove. AMAZING difference. it seams the bank two cat con is almost plugged. my ORX and HPTuners will be here Monday
just wanted to put a post out here for others that run into a similar situation.
Old Feb 26, 2011 | 07:21 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If the cat is plugged, you need to identify the source of the plugging material as in oil or whatever. Obviously you'll need a new cat too.
Old Feb 26, 2011 | 08:46 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
I would test the bank 2 O2 sensor and perform the exhaust system back pressure test before purchasing a new catalytic converter.
Old Feb 26, 2011 | 05:33 PM
lt1ss's Avatar
lt1ss
my x-pipe showed up today
removed the factory mid pipe, put the x in it's place. did a quick tune (no reporting from downstream O2s). car is fixed. just for giggles i cut the cats out of the factory mid pipe and found the honeycomb was in chunks. guessing the front one broke and stopped up the rear cat.
Old Feb 26, 2011 | 07:48 PM
Paul 75 L82's Avatar
Paul 75 L82
What X pipe did you install?
Old Feb 26, 2011 | 08:02 PM
lt1ss's Avatar
lt1ss
i got the Borla to match my exhaust. eventually i am going to get long tubes, and probably go to BNB exhaust when i switch to long tubes. the shorty headers, Borla x and Borla stingers is LOUD at WOT. i will probably get some resonators to go in the x pipe soon.
Old Feb 3, 2022 | 05:26 PM
ARAKNID's Avatar
ARAKNID
If you don't mind, how many miles are on the cats?
Old Feb 3, 2022 | 06:34 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
This OP last posted in 2014…you probably won’t hear from him !!
Old Feb 3, 2022 | 09:17 PM
ARAKNID's Avatar
ARAKNID
Oops. Duh
To p0300 + p1416= stopped up cat con?
