New 14" Rear Rotors
Old Apr 13, 2002 | 07:28 AM
SENNA forever's Avatar
SENNA forever
Default New 14" Rear Rotors
If this is a stupid and crazy idea...be nice!!!
As seen in a previous post the new Eradispeed rear rotors, once used will have a two tone look.The shinny ring part where the pads sit and the other ring part the original plated look.( not nice )
After reading the post and the reply from Baer that fitting the front caliper on the rear will upset the brake balance.
What if,the front caliper is fitted to the rear but first calculate the existing pad surface area on the present rear brake set up,then modify a front pad by machining or drilling at the top and bottom part only, so the new pad surface area touching the rear rotor is the same as standard.
This will then have the same brake balance and the wider brake pad will clean up the full face of the new rear rotor so you get the shinny look.
Note: modify only the soft part of the brake pad so the steel remains intact.
Only for street use and the look.
A few years ago I raced a Mini Cooper did this to fine tune the brake balance but the Vette is another beast.
So what do you guys think? Is it crazy?... Be gentle.
Manuel.
Old Apr 13, 2002 | 07:45 AM
vette.se's Avatar
vette.se
Default Re: New 14" Rear Rotors (SENNA forever)
I do not know if your suggested fix would work but a very cheap and simple fix is to install a rear brake bias control. I think the cost is about $100-120 + labour. Doing this you can set the front/rear brake ratio to whatever you want. If you race it's very usable when running some events on wet surfaces and some on dry. I have AP racing setup in my car installed by DRM.
:cheers:
Old Apr 13, 2002 | 08:23 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
http://forums.corvetteforum.com/zerothread?id=274687
Old Apr 13, 2002 | 06:26 PM
FreddyG's Avatar
FreddyG
Default Re: New 14" Rear Rotors (seanr)
seanr: Mighty Nice ride you've got there!
Old Apr 14, 2002 | 04:58 AM
vette.se's Avatar
vette.se
Default Re: New 14" Rear Rotors (LuvmyC5)
Thanks !
I just got the engine dyno numbers from DRM and they will ship the engine to Sweden next week.
She has been on the lift since May last year after a camchain failure :( So it's all this waiiiting to take her out for the first spin after the engine transplant that's driving me nuts :yesnod:
:cheers:
[Modified by seanr, 9:59 AM 4/14/2002]
To New 14" Rear Rotors
