non function brake lights and blinkers
Old Feb 27, 2011 | 02:08 PM
crashedcars's Avatar
crashedcars
Default non function brake lights and blinkers
Hey guys i have an 04 vert and i can not get the four main brake lights and the blinkers to work. The 5th or upper brake light works and so doesnt the outer running lights in the brake lights the blinker lights do not work at all..... they do not even flash fast in the dash. i have checked every fuse and changed around every breaker. Has anyone ever run into this and do you have any suggestions ??/ I also noticed the front blinkers light when using the remote to lock the vehicle
Thanks T
Old Feb 27, 2011 | 02:42 PM
lucky131969's Avatar
lucky131969
Thanks T
Check minifuse #8, in the passenger footwell fusebox.
Old Feb 27, 2011 | 03:02 PM
lucky131969
To non function brake lights and blinkers
