HELP needed ! Engine misfire .
Old Mar 1, 2011 | 07:32 PM
DAR 2RN's Avatar
DAR 2RN
Cruising
Default HELP needed ! Engine misfire .
I have a 2003 Zo6 with heads and cam , Lt headers and full exhaust . I have owned the car for 5 yrs . About a year ago it started missing under a load . When it does it the speedo and tach bounce around and go back to zero . I have changed plugs , wires , coils , crank sensor, cam sensor, bcm, checked grounds on back of driver side head and on both frame rails . I have also pulled out the battery and checked connections under the battery . the codes are p0300 (always had that code ), u1016, u1096, u1000 , b0516 . Any help would be greatly appreciated !
Old Mar 1, 2011 | 09:53 PM
dougbfresh's Avatar
dougbfresh
If it's a Z, it's probably valve springs.
