BUSHING and COIL OVER INSTALL
Old Mar 2, 2011 | 06:15 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default BUSHING and COIL OVER INSTALL
Anyone have some good directions/instructions on installing a BUSHING kit and COIL OVERS?
If you do...
That would ROCK!
Thanks,
Micah
Old Mar 2, 2011 | 09:26 PM
00Corvette's Avatar
00Corvette
Look up forum member "toque" I'm pretty sure he has some type of a write up on his web page accessible from his public profile here on the forum.
It should be a fairly easy swap.
Old Mar 2, 2011 | 09:27 PM
00Corvette's Avatar
00Corvette
here ya go.. http://mysite.verizon.net/res0aae8/coilover.html
Old Mar 3, 2011 | 01:37 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Originally Posted by 00Corvette
Great link!
Thanks, now I just need to get one for doing the bushings.
Old Mar 3, 2011 | 02:30 PM
memphis_vette's Avatar
memphis_vette
i would be interested in a bushing kit install as well. im looking to do this soon. mine are old and creaky
Old Mar 3, 2011 | 02:37 PM
RedZMonte's Avatar
RedZMonte
A good torch and some patients is the easiest way to get the old bushings out.. Melt'em and slide the new ones in their place. Aluminum suspension parts in a press makes me nervious... if it cracks then you are done.
S
Old Mar 3, 2011 | 02:44 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
S
That's the junkyard mechanic way to do the job.
A hydraulic press can help you with pushing out the stock bushings. You can also use a ball joint press to do the job.
After pushing out the old bushings, it's a pretty simple job to clean up the bores and install the new bushings.
Old Mar 3, 2011 | 02:56 PM
tom01ss's Avatar
0tom01ss
Former Vendor
this is true did it on my neon press makes easy work
Old Mar 3, 2011 | 04:20 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Great idea - TORCH it and push them out. Wonder if they can be cut out?
Old Mar 3, 2011 | 04:30 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Not a bad procedure for a "rookie" ....
Toque
Old Mar 3, 2011 | 04:31 PM
Toque's Avatar
Toque
Question..... how low are you planning to go ? Or are you just going to go with the way LG set it up as you received it.
Toque
Old Mar 3, 2011 | 05:22 PM
MySR71's Avatar
MySR71
Bushing install:
http://forums.corvetteforum.com/auto...s-learned.html
Old Mar 3, 2011 | 07:43 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Toque
What do you recommend? I don't think I want to go as low as I am right now, which is about the same as you are now.
Thanks.
Old Mar 3, 2011 | 08:09 PM
Toque's Avatar
Toque
Your ride height is up to you. I'm just saying that if you want to go low then start off with the shock turned down into the lower housing on front and back more than you think u will need. Turning the shock back out of the lower housing to increase the ride height is no issue....
With that said......
If you start high and want to go lower you run the risk of unscrewing the top part of the shock from the upper mount. Don't ask me how I know this... NOT good !
Toque
Old Mar 3, 2011 | 10:47 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Toque
Can I just start with it at it's lowest point and go up from there? I think that is possibly what you are saying, but wanted to make sure. Thanks for the info!
Old Mar 4, 2011 | 08:44 AM
Toque's Avatar
Toque
Yea you can start as low as you want and go up from there. That's my suggestion. I had NO idea where to start when I installed mine and my back was too low but I turned up the shock to get it right. No issue there.
My front was too high to start with and I found out the HARD way that turning the shock down into the lower housing WILL unscrew the top of the shock from the upper housing...
Leave the spring rates where they are to start off...
Just a FYI for you. Hope it helps !
Toque
To BUSHING and COIL OVER INSTALL
