Help!!! with this electrical problem!!
Old Apr 13, 2002 | 08:16 PM
97 C5's Avatar
97 C5
Default Help!!! with this electrical problem!!
My car wont crank and when I turn on the ignition switch it says low fuel,low tire pressure,low power, etc.. The heater controls are blinking on and off!???!! All of this started when my local stereo shop tried to install an aftermarket cd player(Alpine). What could be the prob? The car is at the sound shop with the whole dash off. Please help!
Old Apr 13, 2002 | 08:30 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: Help!!! with this electrical problem!! (97 C5)
dead battery? :confused:
Old Apr 13, 2002 | 09:11 PM
rhoeven's Avatar
rhoeven
I'd start checking all the fuses first. (under hood & under passenger footwell)
I'll bet you find one or more broken ones.
Good luck
Roger
Old Apr 13, 2002 | 09:36 PM
97 C5's Avatar
97 C5
no blown fuses?? I reset the pcm(I think) still same problem.
Old Apr 13, 2002 | 11:48 PM
plastic thunder's Avatar
plastic thunder
Looks like your local stero shop has a problem :yesnod: Good luck :yesnod:
Old Apr 14, 2002 | 03:15 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
1. Did they use an after market wire harness, or just line taps and butt splices?
2. Have they ever done a C5 install before?
3. Are they MECP certified?
4. Are they insured? :yesnod:
Sorry for the questions but sometimes all aspects need to be looked at.
To Help!!! with this electrical problem!!
