Tach Stopped Working
I have the following codes:
B0521 H Tachometer Signal Circuit Malfunction
B2860 H Telescoping Column Position Sensor Failure
The telescoping column works fine when I move the switch back and forth.
I reset the codes and the B0521 did not come back. The B2860 did come back with an "H."
Any ideas where should I start looking? Think there is any connection between the two codes?
