Another A4 Trans cooler question
Old Apr 13, 2002 | 10:37 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Default Another A4 Trans cooler question
I see a lot of guys go with the B&M 70264 cooler rated 24,000 GVW.
Is the B&M 70266 better at 28,000 GVW? Jegs calls it a Racing Trans Cooler.
Someone had a link to an install, maybe it was WallstAl. Can you post it please?
[Modified by REDGAR, 7:13 PM 4/21/2002]
Old Apr 13, 2002 | 11:21 PM
vstella's Avatar
vstella
Default Re: Another A4 Trans cooler question (REDGAR)
After I rebuilt my 4L60E transmission..I opted for the deeper trans pan..holds extra 2 quarts...easy install and no problems:D
Old Apr 14, 2002 | 12:43 AM
Ripped427's Avatar
Ripped427
I got mine from DRM, its a sweet piece.
Dennis
Old Apr 20, 2002 | 09:45 AM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Thanks for the input guys. Looking for lower cost option
Old Apr 20, 2002 | 10:09 AM
robsvette's Avatar
robsvette
CHEAP!!!
Old Apr 20, 2002 | 10:10 AM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Too Large of a tranny cooler will not hurt you in the end. Over Cooling will cause the converter to lock and unlock.
Old Apr 20, 2002 | 11:08 AM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Default Re: Another A4 Trans cooler question (robsvette)
Rob which cooler do you have in there?
Old Apr 20, 2002 | 03:48 PM
robsvette's Avatar
robsvette
i'm not sure edgar but i know it's definitely a B&M. i had it done a year ago so i don't remember. i'm sure dave at cartek remembers. they'll be in there again for my new 3:73's and 4000 stall TC
Old Apr 20, 2002 | 03:50 PM
robsvette's Avatar
robsvette
hey edgar, what str is your TC? thinking about going to 2.25str
Old Apr 20, 2002 | 07:19 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Good memory!
I sold the 70255 GVW, 16,000 lbs, thats enough cooling for a C5! With the addition of the new T/C, looks like I will have to purchase a new one. :) :lol:
[Modified by wallstAL, 3:22 PM 4/20/2002]
Old Apr 20, 2002 | 07:26 PM
YELLOWDREAMZ's Avatar
YELLOWDREAMZ
Cruise-In II Veteran
Default Re: Another A4 Trans cooler question (wallstAL)
I have the B&M 24,000gvw cooler installed on my C5 now. I had the B&M 16,000gvw installed first but the trans temps were in the 240 degree range on a 70's day at a short racetrack. So, I installed the 70264. I haven't been back to see how good it is at cooling at the track now.
Old Apr 21, 2002 | 07:41 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: Another A4 Trans cooler question (YELLOWDREAMZ)
My car has the B&M 70264 which uses barbs and clamps for fittings- easy to do, you may need to order extra hose (PermaCool sells it in the Jegs catalog). The 70266 "Racing Cooler" is a bit larger but requires threaded fittings and does not have the internal bypass (sorta like a thermostat).
Old Apr 21, 2002 | 08:14 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Thanks Al.
Rob, I am not sure what the STR is on the TC. I bought it used and never asked.
Old Apr 22, 2002 | 01:58 PM
B. Stewart's Avatar
B. Stewart
Default Re: Another A4 Trans cooler question (vstella)
vstella, what pan did you use and where did you purchase it?
Old Apr 22, 2002 | 07:13 PM
Face's Avatar
Face
Default Re: Another A4 Trans cooler question (B. Stewart)
TTT
Old Apr 22, 2002 | 07:49 PM
Speed-Racer's Avatar
Speed-Racer
Default Re: Another A4 Trans cooler question (Face)
I bought Al's cooler and those temps are in the 140-170 most days. I think it got to 190 during a fast 30 mile canyon run.
Seems to be a good cooler for normal driving.
George
To Another A4 Trans cooler question
