EBCM Question?
Old Mar 4, 2011 | 03:22 PM
gregm999's Avatar
gregm999
Default EBCM Question?
Hello all, I have a quick question regarding the EBCM from my 02 Z06. Recently mine went bad and needs to be replaced. I was able to obtain another EBCM for very cheap from a local junkyard, but I'm not sure whether or not it's a working unit. I don't want to install this unit without knowing whether or not it works. Is it possible to simply plug the unit into the factory wiring harness prior to installing it onto the brake pump to test it out? Or, if not, is there any other way to test it out before installing it? This would definitely save me a lot of time. Any advice would be appreciated.
Old Mar 4, 2011 | 04:15 PM
seoulbrooks's Avatar
seoulbrooks
If you just hook the harness up it will run through the self test when power is first applied. It will kick codes if bad....
Old Mar 4, 2011 | 04:18 PM
dougbfresh's Avatar
dougbfresh
What codes is the bad one giving you? You can drive without it till the old one is repaired.
Old Mar 5, 2011 | 07:05 AM
trussme's Avatar
trussme
Default for help on this...
check out Post #66 in this STICKY>>> The Improved***** Ultimate DIY Thread ... *******
To EBCM Question?
