"Figure 8's" After Rear Diff. Fluid Change??
Old Apr 14, 2002 | 03:32 AM
LIGHTNING's Avatar
LIGHTNING
Default "Figure 8's" After Rear Diff. Fluid Change??
Is it necessary to do figure 8's after changing rear end diff fluid? i read this somewhere, but so long as the diff is already broken in, i don't really see why it would be necessary.
Old Apr 14, 2002 | 09:53 AM
RAGGDOLL's Avatar
RAGGDOLL
Toronto Events Coordinator
Default Re: "Figure 8's" After Rear Diff. Fluid Change?? (LIGHTNING)
I think it's to work the fluid thru the axle tubes.
Old Apr 14, 2002 | 09:58 AM
XTrooper's Avatar
XTrooper
Yes, you should do this for the aforementioned reason. It helps to properly distribute the new gear oil. :cool:
Old Apr 14, 2002 | 10:00 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The figure 8's are to get the friction modifier additive up into the posi clutch plates to prevent the groan noise when turning :yesnod:
Old Apr 17, 2002 | 08:38 AM
IMQUIK's Avatar
IMQUIK
Just do it to be safe :yesnod:
Old Apr 17, 2002 | 01:37 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: "Figure 8's" After Rear Diff. Fluid Change?? (mjager)
What axle tubes??
Old Apr 18, 2002 | 12:11 AM
Brutus0725's Avatar
Brutus0725
Default Re: "Figure 8's" After Rear Diff. Fluid Change?? (tshac)
Just do it for fun.......... :D :D :D :D :D :D :D
Old Apr 19, 2002 | 02:42 PM
2kbluestreak's Avatar
2kbluestreak
Default Re: "Figure 8's" After Rear Diff. Fluid Change?? (Brutus0725)
If you are just changing differential lube for preventive maintainance reasons and your positraction wasn't chattering, you probably do not need to immeadiately work the new lube and additive between the clutches. It will distribute there eventually. I've read that a different additive is used by Red Line and Amsoll in their synthetic gear lubes than GM uses in there dino gear lube. :yesnod:
To "Figure 8's" After Rear Diff. Fluid Change??
