I have an 1998, last night I went out started the the car and turned on the lights and they both failed to lift. Does anyone know what fuses and relays are involved in this? I have stood outside the car with the hood up and the motors are not engaging in fact I hear no sounds at all, and I also noticed that the drivers side interior convenience lights are not working. Does anyone have a helpful fuse and relay legend? There was not an owners manual with the car when I bought it.
actually I was hoping for a fuse box legend, which fuses and relays actually control the lights more or less. Then possibly ground locations.. Those are the first two items I wanted to check. But I am going to save that pic for future reference, so thank you!
So if I read this correctly each motor uses a separate fuse, which means this isnt my issue, 10 amp mini fuses 3 & 4 I dont think they would both fail at exactly the same time, any suggestions?
