2001 Corvette turn signals
Old Mar 6, 2011 | 10:05 AM
mwmincey's Avatar
mwmincey
Default 2001 Corvette turn signals
Sometimes my turn signals stop working for awhile.I think this car is haunted.Then all of a sudden,they start back working.Any suggestions ?
Old Mar 6, 2011 | 11:45 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
This is a common problem, your turn signals are connected to your hazards, to replace this is about $40, but you have to tear apart your dash board and it's a pain in the $%&. JW Motoring has a flasher bypass that is easy to install under the drivers side under dash! Good luck!
Old Mar 6, 2011 | 12:27 PM
65GGvert's Avatar
65GGvert
Cycle your hazard button several times quickly, that will usually make them work for a while. Use the search function and you'll find several fixes.
Old Mar 6, 2011 | 05:09 PM
Rebel 1's Avatar
Rebel 1
Common problem on C5's. I fixed our turn signals for a Total of $10.00.
The only thing you remove is the knee panel to do this.
LINK- http://forums.corvetteforum.com/1569256474-post50.html
To 2001 Corvette turn signals
