Brake master cyl swap - cause ABS issues?
Old Mar 6, 2011 | 09:22 PM
onefastls6's Avatar
onefastls6
Default Brake master cyl swap - cause ABS issues?
I need to swap the brake master cyl in my '99 and was wondering if by doing so I would be introducing air into the ABS pump. How can you properly bleed the system after the new cylinder is installed without pushig whatever air is in there through the pump?
Old Mar 6, 2011 | 10:31 PM
Jnape's Avatar
Jnape
Just have the tools and parts needed when you do it. If you leave lines open, hanging and dripping for long you can induce air. I once left my brake lines hanging while I painted the calipers (2 day's). No issues but I drained ALL fluid from the system onto the ground.
