C6 ZR1 hubs on a C5 ??
Old 03-07-2011, 10:56 AM
Austrian Vette
Support Corvetteforum!
Austrian Vette's Avatar
Default C6 ZR1 hubs on a C5 ??
Anyone knows if the C6 ZR1 hubs do fit on a C5 without problems?
edit: just forund ot myself....thanks !
Old 03-07-2011, 11:45 AM
corvettebob1
corvettebob1's Avatar
So is it a secret??????
Old 03-07-2011, 01:27 PM
Austrian Vette
no it´s not
they don´t fit
the ZR1 has different axles
just swapping axles won´t help, though,
as they don´t fit to the C5 diff
Old 03-07-2011, 01:32 PM
dougbfresh
dougbfresh's Avatar
Why would you do this anyway?
Old 03-07-2011, 01:40 PM
Austrian Vette
I will install a Bosch Race ABS into the C5 (racecar).
That Bosch Race ABS needs wheel sensors that send a rectangular signal.
But the C5 sensors send sinus signals.
So if I want to use the race ABS, I need ZR1 hubs.
I will get some custom axles fabricated.
Then it will work.
Old 03-07-2011, 01:42 PM
dougbfresh
dougbfresh's Avatar
What do the Z06 ones do? You can also convert sine waves to square waves-might be easier!!
http://www.discovercircuits.com/C/co-sinetosqr.htm
Old 03-07-2011, 01:46 PM
Austrian Vette
Could do that with the Motec ecu, too.
But Bosch doesn´t want that....they say safety reasons....
Old 03-07-2011, 02:15 PM
dougbfresh
dougbfresh's Avatar
What makes the Bosch so much better than the stock ABS?
Old 03-07-2011, 02:36 PM
Austrian Vette
a lot
it´s
programmable
adjustable
way faster
can brake into corners
Old 03-07-2011, 02:43 PM
dougbfresh
dougbfresh's Avatar
Ever try stock "Competative Mode"??
Old 03-07-2011, 02:47 PM
Austrian Vette
sure
not comparable
To C6 ZR1 hubs on a C5 ??
Quick Reply: C6 ZR1 hubs on a C5 ??
