Oil sender
Old Mar 11, 2011 | 04:14 PM
TOPCATHR's Avatar
TOPCATHR
Default Oil sender
has anyone repalced the oil sender using the method on you tube.
i am refering to removing and replacing the sender with out cutting the cowl or removing the manifold. i have heard about it but want to hear if any one actually did it ............thanks
Old Mar 11, 2011 | 04:27 PM
dougbfresh's Avatar
dougbfresh
There's a video a guy did-search for it.
Old Mar 11, 2011 | 04:43 PM
johnson-rod's Avatar
johnson-rod
I tried like hell and I've got the scars to prove it. Probably over 2 hours into the job I gave up after I broke the top off the sender. In the end I had to pull the manifold.
It took about 20 minutes to pull the manifold. It's so easy a caveman can do it.
No new gaskets, no electrical or plumbing problems when I put it back on.
Started right up and has run fine since.
Don't fear pulling the manifold.
Oh, it was 23 degrees when I did it standing on snow under the shade tree. The leaves were gone and I was racing the sundown.
Old Mar 11, 2011 | 04:48 PM
dougbfresh's Avatar
dougbfresh
Old Mar 11, 2011 | 05:12 PM
1999_TRC's Avatar
1999_TRC
In the time it will take you to post this thread, and sit back and wait for replies, you could have replaced it; by pulling the manifold.
Old Mar 11, 2011 | 05:21 PM
TOPCATHR's Avatar
TOPCATHR
Thanks guys it did seem too good to be true. I have never really heard of anyone doing it, im sure if it were easy no one would remove the manifold. Sometimes you do more work trying to avoid it....lol thanks
Old Mar 11, 2011 | 09:47 PM
Mrgogo's Avatar
Mrgogo
I did the cowl method. Just gotta use the right tools I guess. I had no problems. A deep well socket and a pair of hemostats make it easy work.
Old Mar 12, 2011 | 07:35 AM
rws.1's Avatar
rws.1
there are many in this section that have done it both ways...
the keys to not having to re-do it are
1. meticulously clean the terminals to ensure they are oil free
2. torque to 15 ft pounds.... I usually do so in 3 stages... 8, 12 then 15.
35K miles on my aluminum mexican made replacement sensor.
To Oil sender
