Frankenstein gets a full makeover
Old Mar 18, 2011 | 11:08 PM
Daddyrama31's Avatar
Daddyrama31
Default Frankenstein gets a full makeover
So my 00 vert is getting a full make over. While on the lift I ran into a few problems. So I decided to do the following:
Install a new cam motions cam, a little bigger than the last 228/230 .595/.595 @ 113+4 LSA. New LS7 Lifters and a set of A.I. fully ported/polished 5.3's with larger valves boosting my compression to 11:1. The guys at A.I do killer work. It helps that the owner designed the port design for the GM LS6 Heads. They are works of art. Also ported my TB, added a 391 gear set and slapped in a new LS6 clutch to handle the new power. While in there I decided to add a little bling by adding a Metco crankcase breather and powder coating my valve covers. I decided to scrap the frc's since they create a lot of heat soak. I also switched out my LG non-cated streets for a set of coated and cated Kooks headers. Now all I need is a set of B&B Bullets to replace my Pristine TI's and I be good to go.
For a little inside bling Dennis is hooking me up with the 930BT DD package.
Looking forward to getting it all togather again. I will snap some pics when Frankenstein is off the opperating table.
Just in time for summer time street Fun
Old Mar 18, 2011 | 11:40 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Sounds like you should be doing pretty. Why the LS6 clutch? I dont see it lasting very long with the added power.
Old Mar 18, 2011 | 11:43 PM
Daddyrama31
Budget and I dont drive her real hard. I may do a few track runs but not many. Put in a new slave as well.
Old Mar 19, 2011 | 12:23 AM
00Corvette's Avatar
00Corvette
well it stinks you ran into problems but...CONGRATS!
To Frankenstein gets a full makeover
