Labor on shock install
Old Mar 19, 2011 | 09:37 AM
ricknyc23's Avatar
ricknyc23
Default Labor on shock install
What would a fair price be for the labor only on a set of new shocks?
Old Mar 19, 2011 | 10:32 AM
Luv2Fly's Avatar
Luv2Fly
The Motor Labor Guide shows .7 hours each and 1.0 hour each if select ride equipped. So .7X4 is 2.8 hours, multiplied by 100 per hour is 280.00 or so. Just use your shops labor rate.
Old Mar 19, 2011 | 01:02 PM
mcm95403's Avatar
mcm95403
We did mine last month and that sounds about right. While you're in there, you should replace the sway bar end links with the metal ones if they haven't been changed out yet.
Old Mar 19, 2011 | 01:23 PM
bighank's Avatar
bighank
Default Just did it 1 hour per shock and not a hard task
The rears are a piece of cake. Needed 2 24 mm or 15/16" sockets one regular and one shallow, two socket wrenches, a few extensions and 2 jacks. One under the hockey pucks under side frame member the other under the cradle to raise slightly and remove any loading.
Front a lil more complicated as you compress the shocks and hold with ordinary zip ties. Use the McRat method and you are home free. Got 24 mm socket and 15/16" socket at H F for 1.99 and 2.99. Do it yourself and save $300.
GOTHAM VETTE's Avatar
GOTHAM VETTE
You should try doing them yourself, nothing to it really.
Old Mar 19, 2011 | 01:28 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Then its free and a learning experience. I always do all my car work no matter what it is. It give me a greater satisfaction knowing I did it.
Old Mar 19, 2011 | 01:29 PM
craig04c5's Avatar
craig04c5
I did mine a couple months ago and I ain't no spring chicken. Just use the zip tie method and follow forum instructions. Takes only about 3 hours taking your time and cleaning things up under there. I could do them again in about half that. Search shock install.
Old Mar 19, 2011 | 06:29 PM
dankhts's Avatar
dankhts
took me about 2 1/2 hrs to change my shoicks and sway bars, I have air tools mind you, the part that slowed me down the most was the bottle of vodka!
Old Mar 19, 2011 | 07:40 PM
Armycop's Avatar
Armycop
if you know your way around the business end of a wrench, this is an easy install to do. Give it a try and save some money.
Old Mar 19, 2011 | 08:04 PM
dbbspider's Avatar
dbbspider
I just replaced my F45 shocks with Bilsteins. It took me about six hours to do, but that included soldering in the resistors on the F45 wires, cleaning the inside of the wheels, having lunch, etc. It's not a bad job. Just reserve a Saturday and take your time. Good luck
Old Mar 20, 2011 | 10:10 AM
rws.1's Avatar
rws.1
Changing shocks is easy... There are a couple of DIYs on the forum.
Save yourself the $$$
Old Mar 20, 2011 | 10:12 AM
rws.1's Avatar
rws.1
A lot of shops do not want to install owner provided parts... they will claim it is the warranty/liability issue but it is usually about the lost profit on parts.
I had one shop tell me that at $80/yr they lose money without the profit on the parts... heck they wouldn't even let me choose the brand of part I wanted... insisted it was there choice and their supplier.
To Labor on shock install
