Parking Brake Not Holding
Hey Guys
When ever my 2000 vette sets for a long time like a few weeks. The emergency brake won`t hold. After I drive it a couple of times it seems to be OK. Any suggestions. Thanks
When I changed rear pads and painted calipers removed calipers then rear rotors and adjusted star wheels to have PB shoe just touch inside of rotor surface. The red locktited 125 ft # bolts holding the calipers on are the killers. Mine worked for 5 years but need adjusting again.
When it warms up I'll pull my arms off with a breaker bar and a length of pipe.
BIGHANK
BIGHANK
Not an uncommon problem. Two main possibilities, parking brake shoe adjustment and a faulty parking brake pawl on the hand lever. I'd do the shoe adjustment first, it may solve your problem.
Try these instructions and see if it helps you: http://www.ronjpics.com/Corvettestuff.htm#parkbrake
RonJ ....
RonJ ....
RonJ ....
RonJ ....
I did try yanking it at 45mph or so, and it won't lockup the tires but now it does provide good braking. Before, it was almost nothing.
Those tiny brake shoes on the rear wheels shouldn't be expected to do anything more.
Thanks Everyone
It seems to work and hold well after I use the car a couple of times. But when I first use it after it sets along time sometimes it`s great and other times it won`t hold anything.
If you deploy the parking brake at speed those shoes wear fast. So fast you'll be under your car adjusting star wheels all over again. I use mine only at a complete stop and still have to adjust them about every two years. PITA it is.
