Passenger window problem
Old Mar 21, 2011 | 01:05 PM
mr_unruly2u's Avatar
mr_unruly2u
Cruising
Default Passenger window problem
My passenger window goes Up and Down just fine using the passenger's switch, but it will only go Up using the driver's switch. It will not go Down from the driver's side (no click or noise whatsoever). I've tried a brand new driver's switch bank and it did not change anything (to my great disappointment). All other functions from both switch banks work fine. Any suggestions where to look next would be greatly appreciated. Thanks!
'99 Coupe
Old Mar 21, 2011 | 01:13 PM
C5at57's Avatar
C5at57
Pull back on the black accordian boot by the door hinge and inspect the wireing connector inside. Look for exposed wire going into the connector and for loose pins/sockets in the connector.
Old Mar 21, 2011 | 04:02 PM
Cratecruncher's Avatar
Cratecruncher
It sounds to me also like a bad connector somewhere. You need to use a multimeter and circuit diagram to find the problem. Otherwise, you could be staring right at it and not recognize it's the problem.
Old Mar 21, 2011 | 06:08 PM
mr_unruly2u
Cruising
Ya, I don't have a circuit diagram and was hoping someone would know which pin in the driver's switch connector it was right off-hand. I haven't searched for a diagram yet either, but there's probably a link on this site somewhere to one. Thank you to both of you for the suggestions!
To Passenger window problem
