Code B0367 and B2264
Old Mar 21, 2011 | 02:19 PM
cjragonese's Avatar
cjragonese
Default Code B0367 and B2264
I cleared all the codes but these 2 come back. Ive read a thread on checking the B0367 but lost grasp of it after the second paragraph. In laymans terms, what do these guys say is failing and what should be replaced and where are they located?
Does anyone know?
Carman
Old Mar 21, 2011 | 05:38 PM
00Corvette's Avatar
00Corvette
Does anyone know?
Carman
You'll have to read the whole thread on the AC actuators..it won't get explained any better than the "ac actuator reindex" thread. TONS of us have used just that thread to fix our actuator issues. There are a lot of pictures and links in that thread also.
Check this one out http://forums.corvetteforum.com/c5-t...errerid=228945
best info on the forum for AC actuator issues.
B 2264 is the left door control module..."vertical position sensor fault"
Does the window roll up and down okay?
Old Mar 21, 2011 | 08:56 PM
cjragonese's Avatar
cjragonese
The window works fine but I did replace the motor and everything else about a year ago. It was an after market part and it sounds different than the passenger window but it works fine. Im getting a sound from under the dash that sounds like speaker feedback but when I inspect under the dash I cant find a thing that looks like it makes this kind of noise and of course it only acts up when I put everything back together. ??
To Code B0367 and B2264
