SLP or Granetelli MAF
Old Apr 15, 2002 | 07:50 PM
BLKBLUR's Avatar
BLKBLUR
Default SLP or Granetelli MAF
Which would be better for an 2002 A4?? SLP's is half the cost of a Granetelli. Both claim 12-20 HP. Some claim they work, some have them sitting on the shelf in the garage. I already have a blackwing and don't plan any other mods (except exhaust) for sometime due to funds and warranty issues. :rolleyes:
What's the difference between a MAF and a MAFT?? Would one be better than the other?
Whatever opinions you have are always appreciated :yesnod: Thanks
Old Apr 15, 2002 | 07:57 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Default Re: SLP or Granetelli MAF (Y2K2C5)
Don't know much about the SLP. You can get the Granatelli tuned for the extra air of the Blackwing or other aftermarket air intake. Jus add C to the part #. I have them at a great price.
Old Apr 15, 2002 | 08:01 PM
Bill Vett's Avatar
Bill Vett
:rolleyes: :bs Spend your money on a power loader. I have a G.M.S. maf and I didn't get any 12 to 20 hp. I have also been told that if you power load your car it runs better with the stock maf. Power loader around the same price as a MAF. Just my $.02
Old Apr 15, 2002 | 08:10 PM
Speed-Racer's Avatar
Speed-Racer
Default Re: SLP or Granetelli MAF (Bill Vett)
I have the G MAF and don't think that hp is likely, and you may even lose some. Do a dyno before and after with a:f as well
G
Old Apr 16, 2002 | 12:39 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
I vote for Granatelli :yesnod:
Old Apr 16, 2002 | 04:12 AM
vette.se's Avatar
vette.se
If your car have a correct air/fuel ratio you would gain 0 like most of us have discovered. Those who see gains with a larger diameter MAF or MAF ends most likely had wrong air/fuel ratio from the beginning and got it right with a different MAF.
DRM pulled 586hp/557ft/lbs with my stock MAF (no screen, 2000 model) on my new 427 engine. They added a Z06 MAF which have a larger diameter and the MAT sensor integrated but could not find any more hp on the engine dyno.
I went with the Z06 MAF because it's a much better design with the integrated MAT sensor, you only have to get a adapter cable to use it on a 2000 or older C5(I do not know about the 2001/02). It also looks better because you get rid of the old MAT sensor sticking out from the side of the Airbridge.
You have a 2002 and probably already have a larger diameter Z06 style MAF. My recommendation would be to get a PowerLoader II or have your car tuned on a dyno, I think it would give you the most. If a 586hp car do not gain anything with a larger MAF what could a stock engine gain ?
:cheers:
[Modified by seanr, 9:28 AM 4/16/2002]
Old Apr 16, 2002 | 07:46 AM
Busted Knuckle's Avatar
Busted Knuckle
Paul,
Before you purchase either MAF contact Julio Hormilla @ CARTEK in Garwood NJ. He explained a lot about air flow and screens and such to me on Saturday. I think you would be better off with Julio putting your car on his dyno and tuning your set-up. Ph# 908-317-4496. JMHO :D :cheers: :flag
Old Apr 16, 2002 | 09:34 PM
BLKBLUR's Avatar
BLKBLUR
Thanks as always for your help. I may call Cartek and talk to them and see what they think.
Thanks again :cheers:
Old Apr 16, 2002 | 09:40 PM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
Try a MAFT before the other two. We have them in stock. Dyno tune with it and adjust for a lean or rich condition in percentage and unlike the pre- calibrated aftermarkets MAFs, it's adjustable.:)
If you have a 97-00 LS1 and plan on a head/cam/manifold swap, get the SLP unit to bump up in MAF size. We have those as well. No head/cam/manifold swap plans? MAFTranslator.
..or, let Cartek dyno tune with LS1-Edit as Jim Dawes said. More money but top notch work.
RG
[Modified by RG in Dallas, 7:41 PM 4/16/2002]
Old Apr 16, 2002 | 11:11 PM
tslawsky's Avatar
tslawsky
NEITHER....de-screan your stock MAF....gain the 3-7 detonation free HP from it and spend your $$$$ on a power adding mod!
[Modified by tslawsky, 9:12 PM 4/16/2002]
[Modified by tslawsky, 9:13 PM 4/16/2002]
Old Apr 20, 2002 | 12:27 AM
LTD's Avatar
LTD
Default Re: SLP or Granetelli MAF (seanr)
Thanks for the info. I didn't think MAF added anything, but wanted to hear it confirmed by others.
Old Apr 20, 2002 | 02:03 PM
Dave H's Avatar
Dave H
Default Re: SLP or Granetelli MAF (tslawsky)
Hi: Tried the GMS, had hesitation and surging, went back to stock with no screen. Works just fine, no more problems. :D :D :D
To SLP or Granetelli MAF
