transmission problems
Old Mar 22, 2011 | 04:50 PM
mxn corvettes's Avatar
mxn corvettes
Default transmission problems
i need some guidance, i have a 2002 c5 z06 with 120k and lately i have been noticing that when i drive for awhile its hard to get into the gears especially reverse, and today i was at a red light i put it into first gear and when i was releasing the clutch the gear kicked out violantly .
is it normally hard to get into gears and normal for kick outs to happen.
what do you guys think?
i'm afraid that i damaged my trany what should i do or check?
Old Mar 22, 2011 | 06:17 PM
hornet7's Avatar
hornet7
Default Transmission
Try changing your Trans fluid. This has helped many forum members.
Old Mar 22, 2011 | 07:34 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
If the tranny fluid does not help you might want to pay attention to my post here...
http://forums.corvetteforum.com/c5-t...2-6-speed.html
Toque
To transmission problems
