HVAC help needed
Old Mar 22, 2011 | 09:19 PM
bowtiebubba's Avatar
bowtiebubba
Default HVAC help needed
The hvac unit always displays 69 degrees. What would cause this?
Old Mar 22, 2011 | 09:32 PM
lucky131969's Avatar
lucky131969
Most likely the outside air temp sensor, connector/wiring. Any codes?
Old Mar 23, 2011 | 02:03 AM
00Corvette's Avatar
00Corvette
If no codes, Lucky is right. (as usual)
The outside air temp sensor is located down below the radiator shroud right on or next to the frame rail. Easiest access is lying on the ground with the front of the car jacked up.
You can probably do a resistance check on the connector after you unplug it after doing a visual inspection of the wiring(but I'm not good with a meter so I don't know how).
If you're wiring all looks good, the temp sensor is like 10-15 bucks..contact Gene @ GMPARTSHOUSE
Old Mar 23, 2011 | 05:37 AM
bowtiebubba
Thanks guys. I will give that a try.
Old Mar 23, 2011 | 11:41 AM
rwlc5's Avatar
rwlc5
If when you try to change the temp setting and it does not change or will only vary by a few degrees, you will need to replace the unit. Mine would do that and i also had trouble turning it off even though you would press the off button. I bought a remanufactured unit.
To HVAC help needed
