Service traction after lowering
Old Mar 22, 2011 | 10:19 PM
01C5VETTEMAN's Avatar
01C5VETTEMAN
Default Service traction after lowering
Was just curious what can i do to get my car to stop throwin this code...started after lowering it do i need to raise rear back up or what is best to do? an also to raise rear back to stock do u just turn til all threads are back on top or what is best method thanks for any help....
Old Mar 23, 2011 | 12:42 AM
Cardinal Flyer's Avatar
Cardinal Flyer
I just lowered mine 1/2" front & back; no codes.
Don't remember hearing this as an issue from others who have lowered--might just be coincidence.
Good Luck!
Old Mar 23, 2011 | 08:15 AM
01C5VETTEMAN
well alot people told me careful when i lower it or service traction will appear an bamm lowered it an here it is....i will check wheel sensors where are they exactly located?
Old Mar 23, 2011 | 08:57 AM
cliff_ford's Avatar
cliff_ford
Checking for DTC's will help.
The "diagnostic display" mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button to turn off any warning messages
3) Press and hold "options" , press "fuel" four times within a 10-second period.
When first engaged the on-board diagnostics go into an "automatic" mode.
The computer will show two kinds of codes, "current" and "history," designated "C" or "H".
A current code indicates a malfunction is present in the system whose module is displaying data.
A history code indicates a past problem.
When the screen displays "manual diagnostics," select the desired module by pressing the "options" button
to go forward or the "trip" button to go back.
Press "gauges" to go forward or
"fuel" to go back for each code under a module.
Old Mar 23, 2011 | 12:23 PM
BigGun's Avatar
BigGun
The sensors are built into the hubs. Check the connector on the back of each hub and see if all are connected securely. It gets harder after this...check those codes as they will give you more of an idea of whats going on.
To Service traction after lowering
