Electronic bake controller question
Old Mar 24, 2011 | 12:52 PM
Kingman99's Avatar
Kingman99
Default Electronic bake controller question
Hi
My friend is having a problem and l was not able to help and thought maybe a fellow foum member could.
I have a question for you, my electronic brake controller went and they don't make the part anymore and two different companies could not rebuild it.. I was wondering if you still get on corvette forms if you could look for me, I have a 1998 corvette with traction control and active handling as well as abs, from what I am told very few cars were made with all these features
Alan
Old Mar 24, 2011 | 01:30 PM
dougbfresh's Avatar
dougbfresh
Originally Posted by kingman
Hi
Alan
Is there a question here? Can't recognize the language
Your a Senior Member here with many posts, the EBCM thing has been covered 100's of times now.
Old Mar 24, 2011 | 01:38 PM
Kingman99's Avatar
Kingman99
Default EBCM's
Hi
Never ever had a problem with this and my friend said that because he has the active handling option along of course with the ABS and traction control, it's l believe the active handling has a different controller. His shop was unable to fix his and sent it out to 2 different places that said they can't fix it. Keepin mind it's a 1998.
I went from a 96 to an 02 and never had to do anything but regular maintenance.
I will go through the EBCM search's to see what l can find.
Old Mar 24, 2011 | 01:51 PM
dougbfresh's Avatar
dougbfresh
You'll have to find one from one of the Corvette salvage places, GM no longer stocks them and nobody seem to repair the early ones.
Old Mar 24, 2011 | 01:53 PM
lucky131969's Avatar
lucky131969
Hi
Since it's a 98, does it have a front or rear mounted EBCM?
Old Mar 24, 2011 | 01:55 PM
Kingman99's Avatar
Kingman99
Hi
l will go over this with my friend to get a cleared picture rather then guess.
Thanks again
Old Mar 24, 2011 | 02:30 PM
lucky131969
Hi
Thanks again
In the event that he has a front mounted EBCM, the parts manual indicates that a 98 (with JL4, JL9 front mounted aka "JAG"), and a 99 (with JL4,JL9)....are the same part number. If this is the case, there is a EBCM in the parts section....for a 99 with JL4.
http://forums.corvetteforum.com/c5-p...bs-module.html
Old Mar 31, 2011 | 07:51 PM
Kingman99's Avatar
Kingman99
Default On the right track
Thanks a lot my friend is on a list and he is #11 for the transplant. Found an older thread where we were able to get pointed in the right direction.
Thanks again
Old Mar 31, 2011 | 07:56 PM
lucky131969
Thanks again
To Electronic bake controller question
