Need Imput!!
Old Mar 26, 2011 | 01:15 AM
sdmeineke's Avatar
sdmeineke
Default Need Imput!!
Just had the trany rebuilt and a new clutch put in.3rd time cars been on the road since the rebuild. I was in first on a role, got off into it and when I shifted to second it started clattering and vibrating the car. Putted home with chatter coming from under and in front of shifter still have chatter while car is in nuetral and i rev it. any input guys?
Old Mar 26, 2011 | 04:37 AM
zeevette's Avatar
zeevette
I'd guess that your clutch installer screwed up the pilot bearing when he tried to slide the input shaft in. It's fairly easy to do. Hopefully, your installer will guarantee their work. Could be a coupler, too.
Old Mar 26, 2011 | 09:35 AM
sdmeineke's Avatar
sdmeineke
theres a year warranty parts and labor..its just that the shop is 270 miles away..gona have to pull it on a car hauler there..its felt like its had a small vibration in the higher rpm range since the install but i figured it was because of the lighter flywheel..sure raps quicker..thanks for the imput..
To Need Imput!!
