1998 codes 0654, 1518, 1571
Old Mar 26, 2011 | 11:11 PM
Raine911's Avatar
Raine911
4th Gear
Default 1998 codes 0654, 1518, 1571
Picked it up for a good deal due to issues. Car went into storage 6 mos ago due to reduced engine power. Friend pulled PCM and cleaned all connectors; no change. Tow truck ride to the dealership. Hope it's an easy fix but nothing is ever easy. Friend recommended buying a battery box to prevent corrosion from running down to PCM which is conveniently located under the battery? More to follow.
