Led swap for instrument cluster
Old Mar 27, 2011 | 02:31 PM
Bad97ta's Avatar
Bad97ta
Default Led swap for instrument cluster
ive tried the search option and had a hard time finding a step by step install for the lights in the instrument cluster. not the black light ones but the speedo, oil pressure..... and other gauge lights. if anyone has changed theres out or knows how i would like to pick your brain or see how it was done correctly. thank you in advance
Old Mar 27, 2011 | 03:39 PM
johnpowe's Avatar
johnpowe
I think this is what you want. good luck
http://www.spdkilz.com/techtipleddic.html
Old Mar 27, 2011 | 05:23 PM
Bad97ta's Avatar
Bad97ta
ive already replaced those. but if you look in pic 41 (second to last) it shows how the tach is lite up blue. that is what im trying to change. i already have everything changed just need to do the actual instrument cluster.
Old Mar 27, 2011 | 06:59 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I see what your saying how the speedo/tach are blue-ish in the pics...
I'm thinking its stock looking blue a little... Mine has a blue look to it too... (see mine below)
Old Mar 27, 2011 | 07:34 PM
lionelhutz's Avatar
lionelhutz
But all the guages are lit-up by the black lights.
Peter
Old Mar 27, 2011 | 07:42 PM
_zebra's Avatar
_zebra
from what i understand, the speedo/tach/oil pres/fuel/coolant temp/volt are all front-lit by the blacklights
Old Mar 27, 2011 | 08:30 PM
rehirsch8's Avatar
rehirsch8
Does the dimmer still work with LEDs? I love the look but I need them dimmer when driving on country roads.
Old Mar 27, 2011 | 09:27 PM
Bad97ta's Avatar
Bad97ta
well i was doing some more searchin and found that jwmotoring HAD a el glow faceplate that had a tinted cover for the gauges. but that thread was over 2 years ago and they no longer have this on the website.
Old Mar 28, 2011 | 08:32 AM
Toque's Avatar
Toque
The dimmer still works fine with the LED upgrade.
Toque
To Led swap for instrument cluster
