oil pressure
Old Mar 28, 2011 | 01:37 PM
billyward's Avatar
billyward
Default oil pressure
what is the oil pressure for a 1998 corvette?
Old Mar 28, 2011 | 04:16 PM
TwinTurboZ51's Avatar
TwinTurboZ51
80 psi when cold
once warm I get around 62 PSI
Old Mar 28, 2011 | 04:55 PM
lucky131969's Avatar
lucky131969
Originally Posted by TwinTurboZ51
80 psi when cold
Old Mar 28, 2011 | 06:19 PM
ZZ06's Avatar
ZZ06
80 psi when cold
i hope that was a joke......to the OP cold around 50+/-psi. hot idle around 35+ psi and WOT 55+psi
Old Mar 28, 2011 | 06:57 PM
SG Lou's Avatar
SG Lou
80 psi when cold
Ya got me .............for about a split second,
then it dawned on me !
Old Mar 28, 2011 | 07:48 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
In the heat of the summer with the HVAC running and so on, I'm seeing 19 psi at idle and around 35-38 while driving. This is with over 300k miles on the engine. Minimum required to operate is 6 psi and if it ever gets that low, time to take it apart and do some repairs.
Old Mar 28, 2011 | 08:10 PM
billyward's Avatar
billyward
Default triple malfunction
i have three things out at one time could they be related? cruise won`t engauge ac won`t come on but heat does, and the abs and traction controll light won`t work.
Old Mar 28, 2011 | 08:15 PM
billyward's Avatar
billyward
Default c 5 oil pressure
can you tell me the eng oil pressure for a c5 the gm corvette book only says it varies.
Old Mar 28, 2011 | 08:27 PM
billyward's Avatar
billyward
Old Mar 28, 2011 | 08:32 PM
lucky131969
Not sure what "GM Corvette book" you are referring to....
Old Mar 28, 2011 | 09:06 PM
billyward's Avatar
billyward
thanks for the specs. idle 28 psi 2000 rpm 40 psi 3000 rpm 50 psi. i got pretty good oil pressure.
Old Mar 29, 2011 | 03:13 AM
ZeeOSix's Avatar
ZeeOSix
80 psi when cold
Obviously this is possible if at some RPM much higher than idle ... like around 5000~6000 RPM. 80 psi is indication the oil pump is in pressure relief.
Old Mar 29, 2011 | 08:23 AM
dgrant3830's Avatar
dgrant3830
I suggest you pull your codes for the problems you are having. That will tell us a lot more.
To oil pressure
