Which oil Mobil1 5-30 or 10-30?
The June 2009 GM4718M standard lists Mobil1 0W-30, so I thought I would give it a try. BLUF = the average on my daily drive went from 22.4 mpg to 24.8 (an increase of 10%). My daily drive is 56 miles. I start at 2,600’ elevation, drive up the hill to 4,200’ elevation and then back to 2,600’. This first part is 63 mph (cruise on) for 20 miles the next part of the drive is 8 miles of city driving, then reverse to go home. I have been doing this drive for a year and switched to 0W-30 1,000 miles ago. I “do the math” at every fill-up and these numbers are verified. I don’t have any financial or other interest in Mobil1…your mileage may vary. My ride is a stock 03 convertible with an A4, K&N filter and Hypertech tune...and I have 3.15 gears
Oil discussions on here get as heated as religious and political discussions in other circles
But that's only my guess for the claimed 10% mileage improvement.
RedVette, check out the article in this topic:
http://forums.corvetteforum.com/auto...about-oil.html
Also, check out www.bobistheoilguy.com.
Have a good one,
Mike
#34
I understand what you're saying very well, but the key words here are SHOULD be the same. I'll bet they are not the same when hot, hence the mileage improvement claim with the 0W-30 oil.
#36
Let me say it this way: Although both oils MEET the hot viscosity standards of SAE 30 oil, their individual hot SUS ratings are are not EXACTLY the same.
#38
Actually, at typical startup temperatures, 5w-30 viscosity is definitely lower than that of 10W-30. In fact, a Mobil 1 applications engineer told me that 10W-30 is essentially, obsolete in that not only does it NOT protect your engine better at high temps, but it also takes longer to circulate at startup, when most engine wear occurs. The Mobile 1 engineer uses 0W-40 in his truck for that reason.
#39
Probably b/c it's the best weight suited to cover all applications in all areas and environments that the vehicles may be running in. Not one weight will be perfectly optimal for every situation, so auto companies try to find a best average oil to recommend for a vehicle to make it easier on the average Joe. But average Joe's get this information and obsess about oil brands and weights like you see happening in this thread.
