Hi, i am doin my first head change and i was just wondering what size head gasket (Thickness) i would need. i am just going from ls1 241 heads to The ls6 243 heads, also< am i safe to just go with the GM gaskets or should i go with FEL-PRO or another brand? thank you!
Anthony
I have not heard anything negative about GM gaskets......have you?
no.. i just wasent sure if it was worth spendin the extra money for felpro or not. lol. another question though.. do i have to change the head studs when i do a head change or just the bolts? (my car only has 40,000mi)
If your car is stock, you have bolts, not studs..........unless head work was done before, and studs were installed.
I would put a set of GM MLS head gaskets on. They will work fine with your setup and are fairly inexpensive. We have them in stock. I believe they are $49.99.
I am glad you posted this, a buddy has a C5 z06 and is getting ready to do a cam and head swap. He is giving me his 02 z06 cam and heads for a great price so you just saved me some research.
I have an LS6 shortblock in my shop, cleaning up the deck surfaces in preparation for head install. Getting that old graphite stuff cleaned off is a real bear. No nicks on the decks thus far, going nice and slow using a plastic putty scraper and paint thinner.
I wouldn't waste the time putting that z06 cam in now is the time to get yourself a stout cam....... if your going to do a cam swap why not go with something thats gonna yield some more horses
5.3 guys like those z06 cams they make nice turbo cam in a 5.3
