Traction control almost killed me!!!!!!!
I have a 2001 vette, What would give me the most power from a dead start? Thanks in advance for your answers and time
Yes, competitive mode for drag racing. How you lauch the car depends on your setup....i.e. auto/manual, street tires/drag radials, power level, etc.
If I have it on Comp Mode even with my big rear tires it still wants to fish tail a bit when I floor it, so I have to feather it first then floor it.
I read I could run the car on 2nd gear on the auto trans for great power and speed off the line and actually leave it there through out the race, True?
One more question Lucky and thanks for all your help
I am new with a C5 car please explain?
Everyday driving - Handling ON
??????????????? - Handling off (why?)
Comp Mode (when) to Drag race??
"If you leave it on, when you break traction, the PCM will pull timing to control the torque. Not what you want to happen, when you are doing a burnout....drag racing, etc. While the traction control is off, you are still able to take advantage of the Active Handling. Some guys don't like it, but it's straightened me out a few times, when the car got squirley."
I acknowledged, that I mean to say :
"If you leave it off, when you break traction, the PCM will pull timing to control the torque. Not what you want to happen, when you are doing a burnout....drag racing, etc. While the traction control is off, you are still able to take advantage of the Active Handling. Some guys don't like it, but it's straightened me out a few times, when the car got squirley."
...and that's as far as I'm going. If you want to learn more....google answers a lot of questions......I'll give you a head start.
http://corvetteactioncenter.com/tech...ehandling.html
Comp mode (holding down 5sec) will turn off traction control but leave AH on so if you get squirrely the car will still try to straighten out.
Turn off, the dash light comes on and you are on your own.....
Summary
There are 3 modes
1) Traction Control Off, Active handling Off
2) Traction Control On, Active handling On
3) Competitive Driving = Traction Control Off, Active Handling On
Traction Control (TCS)
•This limits wheel spin by working the rear brakes and reducing engine power.
•TCS comes on automatically when you start the car.
•If it engages (i.e. if you start spinning the wheels and it kicks in to reduce spin), the DIC shows TRACTION SYS ACTIVE (momentarily)
•To toggle TCS on or off, press the Active Handling button on the center console briefly. This will also toggle the Active handling System in conjunction with TCS. The DIC will briefly display "TRAC/ACT HNDLG -ON" or "TRAC/ACT HNDLG -OFF".
•If it is OFF, then the skidding-corvette-rear-end light (TCS light on the instrument panel) is ON.
Active Handling System
•Active Handling helps maintain directional control by selectively applying any one of the vehicles brakes.
(The video has an interesting segment on this feature)
•Active Handling comes on automatically when you start the car.
•If it engages to regain vehicle control, the DIC says "ACTIVE HANDLING" (briefly).
•If you turn the Active Handling System Off, the traction control system will also be turned off. It is toggled on or off the same way the TCS system is toggled (see above)
Competition Mode:
•Competitive Driving mode allows the driver to have full control of the rear wheels while the Active Handling system helps steer the vehicle by selective brake application.
•When on, the DIC displays "COMPETITIVE DRIVING"
•To turn on Competition Mode, press the Active Handling button on the center console for more than 5 seconds.
•To turn it off, press the button briefly. Does the active handling/traction control then turn ON?
The manual states that ABS remains on with the traction control and Active Handling Systems off. I assume this means it also remains on when in Competitive Driving mode?
