Fuel pump...
Old Apr 2, 2011 | 12:15 PM
cscarlson50's Avatar
cscarlson50
Default Fuel pump...
My fuel gauge would be at 3/4 of a tank and fropp to empty... also had erroe codes ..translated to lean fuel bank 2,,
had diagonised by three dealerships ..fuel pump
$800 fuel pump replaced
Old Apr 2, 2011 | 12:20 PM
lucky131969's Avatar
lucky131969
So only one bank was leaning out, and they replaced the fuel pump? Fuel sending unit issues are common, and are not associated with fuel supply............unless you were truly running out of fuel.
Old Apr 2, 2011 | 12:31 PM
corvettebob1's Avatar
corvettebob1
I agree with Lucky, typical stealership technique replace the fuel pump assembly for a bad/dirty sending unit.
Then clear the codes and see if he comes back for the intake leak so we can get him again for the other problem.
Old Apr 3, 2011 | 10:46 AM
cscarlson50
I went to 3 separate places for diagnoises..... have been driving the corvette and no problems now....
Old Apr 3, 2011 | 02:36 PM
torchredfrc's Avatar
torchredfrc
I replaced the fuel pump in my C5 with a Lingenfelter fuel pump (high flow) for around $260. I'm shocked every time I hear what dealers charge for this type of service. What year is your car?
Did they also replace the filter/pressure regulator for you?
Old Apr 4, 2011 | 08:51 AM
cscarlson50
Yes they did change those things.. with the fuel pump and labor thats where the cost goes up.. i couldn't change it myself..sooo
To Fuel pump...
