I have a check engine light on giving me code P0410! Does any one knows what would be the problem or what do I have to do or replace??
I appressiate your advise.
From: LA/OC border, probably sittin' under the patio, by the pool...smokin' a cigar! SoCal
Originally Posted by 2000redcorvette
I have a check engine light on given me code P0410! Does any one knows what wold be the problem or what I have to do or replace??
I belive that is an emission air pump code. Check fuse,
if you live were its cold somtimes moisture inside will freeze and make the motor pop a fuse cause it cant turn.
there are other obviouse reasons that a fuse might blow, but this is one that most people overlook.
I will check that fuse because it was wreck on the front and they replace all that things and maybe the fuse blow out with the crash.
Thank you for the advise.
