H.U.D help
Old Apr 4, 2011 | 01:46 PM
Dax FRC 2000's Avatar
Dax FRC 2000
Default H.U.D help
H.U.D is working but I can’t see it until I sit up very high in the seat. Is there a way to adjust the H.U.D on a C5 Corvette? It came stock with the car. Thank you in advance for the help.
Dax
Old Apr 4, 2011 | 01:59 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
There is an adjustment on the upper left of the IP bezel that should adjust it up and down. If it doesn't it needs repaired.
Old Apr 4, 2011 | 02:03 PM
Dax FRC 2000
The adjustment is not working. Is there a diffrent way to adjust. Thank you for the help.
Old Apr 4, 2011 | 02:24 PM
Redeasysport
The gears break try searching "HUD repair" or "broken HUD". I ain't pretty gotta pull the dash.
http://forums.corvetteforum.com/c5-t...d-display.html
Old Apr 4, 2011 | 04:50 PM
65GGvert's Avatar
65GGvert
Are you pushing the + button (not the slide switch for brightness)? I haven't seen one that wouldn't adjust that was still up on the windshield. Usually when they break, the fall all the way down. I guess the motor could be stuck. Interested.
To H.U.D help
