My 2000 C5 right headlight just started making a clicking noise after the light assembly has closed. Is this a sign that the headlight actuator needs replacement and if so is this a difficult process.
you need to make sure you get the right kit depending on your Vette year.
I consider myself to be slightly mechanically inclined. Oil change, replace filters, and I can follow instructions. Nothing big. I was able to do this without any issues at all.
Beats buying a whole new headlight motor with the same plastic gear...
The important thing is insuring the spacers/washers go back where they belong. It can be assembled slightly wrong and still go together. Just pay attention to what goes where and you'll be fine.
