Instrument Panel Cluster (IPC) Replacement
Old Apr 7, 2011 | 11:33 AM
cjragonese's Avatar
cjragonese
Default Instrument Panel Cluster (IPC) Replacement
Im replacing my cluster, C5. Does anyone have a link on the procedure for this?
Thanks.
Old Apr 7, 2011 | 11:39 AM
rwlc5's Avatar
rwlc5
I'm not sure on this, but check the vetteessentials website for instructions on intalling gauge bezels. That will have the entore process for removing the cluster.
Old Apr 24, 2011 | 12:24 PM
cjragonese's Avatar
cjragonese
Great info. I replaced the cluster and HUD in 2 1/2 hours.
-No pieces left over!!
Old Apr 24, 2011 | 02:59 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Do not forget that you need to arrange to update the odometer to match the original or you'll cause yourself serious legal issues.
Old Apr 24, 2011 | 06:21 PM
cjragonese's Avatar
cjragonese
Correct sir....The originl cluster is being repaired and the milage will be updated pror to reinstall..
Old Apr 24, 2011 | 10:11 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I'm not real sure on this, but couldn't you have driven your car without the cluster in place until it was repaired?
To Instrument Panel Cluster (IPC) Replacement
